FMS T-28D T28D Trojan V4 Silver 1400mm Wingspan RC Airplane PNPSYMA X22W WIFI FPV With 720P Camera APP Controller Altitude Hold Mode RC Quadcopterr RTFFlysight Falcon FG01 2D 3D 16:9 4:3 FPV Goggles Glasses Built-in DVR HD Port for RC DroneiRangeX IRX4 Plus 2.4G CC2500 NRF24L01 A7105 CYRF6936 4 IN 1 Multiprotocol STM32 TX Module With CaseMulti Protocol TX Transmitter Module Case for FrSky FlySky TransmitterJumper T8SG Multi-Protocol 2.4G 10CH Compact Transmitter for Flysky Frsky DSM2 Walkera Devo FutabaEachine 1000TVL 1/3 CCD 110 Degree 2.8mm Lens Wide Voltage 5-20V Mini FPV Camera NTSC PAL SwitchableYD-711 2.4GHz 4 Channels Infrared RC Helicopter Drone Flying Toy
Walkera Goggle 4 5.8G 40CH 5 Inch Diversity FPV Goggles Bulit-in 7.4V 1200mAh Li-Po For RC DroneJumper T8SG Multi-Protocol 2.4G 10CH Compact Transmitter for Flysky Frsky DSM2 Walkera Devo FutabaQiJun 1812-1 2.4G 30KM/H High Speed Wireless Remote Control  Rc Boat With Battery2.4G CC2500 NRF24L01 A7105 CTRF6936 4-IN-1 Multi-protocol STM32 TX Module With Antenna2 Pieces APC Style 5050 5x5 DD Direct Drive Propeller Blade CW CCW For RC AirplaneiRangeX IRX4 2.4G CC2500 NRF24L01 A7105 CYRF6936 4 IN 1 Multiprotocol STM32 TX Module With CaseSonicmodell HD Wing 1213mm Wingspan EPO FPV Flying Wing RC Airplane KITNew Version Upgraded Hubsan X4 V2 H107L 2.4G 4CH RC Drone Quadcopter RTF5.8G 40CH Raceband Anti-Interference AV Three-Channel FPV Receiver with Memory Storage FunctionEachine E013 VR006 VR-006 One-antenna 3 Inch 5.8G 40CH Mini FPV Goggles Build in 3.7V 500mAh Battery
Интересности с АлиЭкспрес
Re: Интересности с АлиЭкспрес
Конструктор для сборки машины автоматического пускания мыльных пузырей! :-)
http://rc-aviation.ru/components/com_agora/img/members/3/booble-pusher.jpg
Купить Small Hammer STEAM DIY Bubble Blister Robot Machine Educational Kit:
- BangGood: http://rcmove.ru/czk
- AliExpress: http://rcmove.ru/czj
Не падает тот - кто не летает!!!   Все вопросы - в форум! Личка только для личных сообщений. Ангар: http://rc-aviation.ru/forum/topic?id=7259
29943 Сообщений
Паровые двигатели (не стирлинг!)
http://rcmove.ru/czq
http://rcmove.ru/czr
http://rcmove.ru/czs
http://rcmove.ru/czt
С ними можно сделать вот такую лодку, причем не только на паровом двигателе, но и на радио управлении!
А если есть станок, то и на паровой турбине!
29943 Сообщений
Более двух тысяч различных запчастей для ремонта бытовой техники.
http://rc-aviation.ru/components/com_agora/img/members/3/all-remont-zapchast.jpg
Посмотреть, что есть в ассортименте: http://rcmove.ru/d1j
29943 Сообщений
Автомобильное зарядное устройство FIVI с поддержкой QC 3,0
http://rc-aviation.ru/components/com_agora/img/members/3/auto-charger.jpg
Хорошая зарядка. Держит нагрузку 2.9A на порту 5V и 3.15A на порту QC 3.0 Поддерживает быструю зарядку для смартфонов на MTK, что может не каждое зарядное устройство. Порты зарядки независимые. Если нагрузить один порт, напряжение на другом не падает. В гнезде прикуривателя сидит плотно, не болтается.
- Заказать зарядку для автомобиля: http://rcmove.ru/d4q
29943 Сообщений
Магнитные держатели шурупов на биту шуррупверта
http://rc-aviation.ru/components/com_agora/img/members/3/magnit-bita.jpg
Удобные универсальные магнитные насадки на сменные биты шуруповёрта. В комплекте пришло пять штук. Сильные магниты. На фото видно, как хорошо держится шуруп (3,5х40) в горизонтальном положении. Шикарно использовать при работе на потолке или стене - не нужно заморачиваться с дополнительной фиксацией шурупа на бите. Доставили в Москву за календарную неделю. Трек отслеживался весь путь от Гонконга.
- Заказать магнитные держатели: http://rcmove.ru/d4r
29943 Сообщений
Компактный мультитестер в футляре
http://rc-aviation.ru/components/com_agora/img/members/3/compact-multitester.jpg
Фактически футляр является корпусом мульттестера, удобно, если тестер лежит в коробке с другими инструментами или в полетном чемоданчике.
- Заказать компактный мультитестер можно тут: http://rcmove.ru/d8b
29943 Сообщений
Подогрев картера автомобиля для легкого запуска мотора в -20 и ниже.
http://rc-aviation.ru/components/com_agora/img/members/3/podogrev-kartera.jpg
Идет с липкой стороной, при установке желательно пройтись герметиком по периметру установки.
- Заказать подогрев мотора можно тут: http://rcmove.ru/d8l
29943 Сообщений
Набор инструмента "для девочек"
http://rc-aviation.ru/components/com_agora/img/members/3/pink-instrument.jpg
- Дорогая, теперь чини все сама! Вот и инструмент для тебя! :-)
- Заказать розовый инструмент можно тут: http://rcmove.ru/d8s
29943 Сообщений
Разные RC машинки масштаба 1:12 по очень привлекательной цене!
https://sun9-15.userapi.com/c855420/v855420029/15733f/Ru3knnSd47w.jpg
- Смотреть машинки: http://rcmove.ru/d8t
29943 Сообщений
Решил одзаказать всякого инструмента к следующему лету
Универсальная головка
Для серьезной работы не пойдет, но подзакрутить быстренько - норм. Беру для закручивая шурупов с кольцом, на них удобно веревку натягивать. А вот закручивать их - чистое мучение, если больше 2-4 штук :-)
- Купить универсальную головку можно тут: http://rcmove.ru/dlf
Магнитный держатель шурупов - удобно работать шуруповертом одной рукой
- Заказать магнитный держатель шурупов: http://rcmove.ru/dlg
Точилка для сверел (кондуктор)
http://rc-aviation.ru/components/com_agora/img/members/3/zatochka-swerel-1.jpg
Беру комплект с запасным точильным роликом. Ролики можно заказать и отдельно.
- Заказать точилку для сверел можно здесь: http://rcmove.ru/dlh
Набор мелких сверел 1/1. 5/2/2,5/3 мм
http://rc-aviation.ru/components/com_agora/img/members/3/nabor-swerel-2019-1.jpg
Мелкие заразы быстро ломаются и тупятся... Но теперь еще будет точилка :-)
- Заказать набор мелких сверел: http://rcmove.ru/dlj
Ступенчатое сверло 3-13 с шагом 1 мм
http://rc-aviation.ru/components/com_agora/img/members/3/stupen-sverlo-1.jpg
Сверлить таком надо на малых оборотах, с подкапыванием масла, листовой материал (квадратные трубы тоже норм) и по уже готовой дырке!!! На ютубе обзорщики сверлят сразу ступенчатым - это неправильно!  Задолбаешься потом затачивать первую ступеньку. Сверло прямое - затачивать его будет легко.
- Заказать ступенчатое сверлоhttp://rcmove.ru/dli
Срезатель фаски с труб. шпилек, кругляка
Особо актуально при резке шпилек и болтов!
- Заказать срезатель фаски: http://rcmove.ru/dlk
29943 Сообщений
Для изготовление подсветки рабочей зоны стола и самодельного софтбокса
Светодиодная лента
http://rc-aviation.ru/components/com_agora/img/members/3/swetilnik-1.jpg
- Заказать светодиодную ленту можно тут: http://rcmove.ru/dmc
Регулятор яркости - точнее плата регулятора мощности тока с ШИМ контроллером, подходит для управления оборотами моторов (шпиндели ЧПУ), яркостью светодиодных лент и тд.
http://rc-aviation.ru/components/com_agora/img/members/3/swetilnik-2.jpg
Из за использования высокочастотного ШИМ нет мерцания ленты на низкой мощнсти (светимости ленты).
- Заказать регулятор мощности можно здесь: http://rcmove.ru/dmd
29943 Сообщений
Блок питания с регулировкой напряжения
http://rc-aviation.ru/components/com_agora/img/members/3/bp-reg.jpg
- Заказать блок питания с регулировкой напряжения можно тут: http://rcmove.ru/dme
29943 Сообщений
Всего сообщений сегодня:
5
KAIEN
konst, carpenter, kompmen, cnyx, Dragony, Student, maks_dg, Goby, alldn, nikolaypet
1) Скидки на RC товары
2) Интересности с АлиЭкспрес
3) Про полёты закон бпла
4) Не храните деньги в банках :(
5) Надо больше золота!!! (с)
6) Полет на 40 км с 5.8ГГц
7) Не модельное но прикольное
8) Я новичек
9) Youtube
10) Электрические транспортные средства
1) Я новичек - Хочу собрать первую модельку
2) Движок от триммера на авиамодель - или на любую другую самоделку...
3) Обзор FlySky FS-I8 - пульт радиоуправления
4) Помехи FPV
5) Продаю вертолет Hirobo S. R. B Quark новый
6) Контроллер Matek 411 Wing - Подключение ПК к приемнику
7) Простые авиамодели - видеообзоры изготовления авиамоделей
8) Для миниатюрных летающих дронов предложен новый тип крыла
9) Горе друг который сделал короткое замыкание
10) Какой пульт выбрать для RC самолета - и дрона тоже
