- » Универсальный ВЧ блок
Заказал Multiprotocol TX Module For Frsky X9D X9D Plus X12S Flysky TH9X 9XR PRO Transmitter
По описанию - можно управлять практически любыми мелкими квадрокоптерами с больших пультов :-)
Жду когда придет (сегодня отправили), а то мелкие пульты просто неудобны!!!
Управляет: Cheerson,Syma,Wltoys , Eachine E010 (Most of these brand's quadcopters, helicopters and airplanes are compatible but not every model.Specific models please check instruction under the note)
Вставляется: Frsky X9D/X9D Plus/X12S, flysky TH9X, Turnigy 9XR/9XR PRO и (как предполагаю) Taranis.
Заказывал
Re: Универсальный ВЧ блок
Инструкция для Multiprotocol TX Module For Frsky X9D X9D Plus X12S Flysky TH9X 9XR PRO Transmitter
TOY-MTX Instructions
Binding Procedure
1. Create a model in OpenTX using external module in PPM mode, 12 channels and AETR
sequence order. 2. Turn off Taranis. 3. Power up quad. 4. While holding the appropriate stick pattern listed below, power up Taranis. Arm quad based on it's firmware's specification. Protocol is selected with stick position at startup:
Rudder right + Aileron right + Elevator down = EAchine E010, NiHui NH-010, JJRC H36 mini
Rudder right + Aileron right + Elevator up = FQ-777-124 Pocket Drone
Rudder right + Aileron left + Elevator up = CX-10 older red PCB/CX11/CX205/CX30, JXD389/391/393, SH6057/6043/6044/6046/6047, FY326Q7, WLToys v252 Pro/v343, XinXun
X28/X30/X33/X39/X40
Rudder right + Aileron left + Elevator down = WLToys V930/931/939/966/977/988
Rudder right + Elevator down = HiSky RXs, HFP80, HCP80/100, FBL70/80/90/100, FF120, HMX120, WLToys v933/944/955
Rudder right + Elevator up = Syma X5C (older model), X2 ... Rudder right + Aileron right = MJX X600
Rudder right + Aileron left = EAchine H8 mini 3D, JJRC H20/H22
Elevator down + Aileron left = Syma X5C-1/X11/X11C/X12
Elevator down + Aileron right = Attop YD-822/YD-829/YD-829C ... Elevator up + Aileron right = EAchine H8(C) mini, BayangToys X6/X7/X9, JJRC JJ850, Floureon
H101 ... Elevator up + Aileron left = EAchine H7
Elevator up = WLToys V202/252/272, JXD 385/388, JJRC H6C, Yizhan Tarantula X6 ... Elevator down = EAchine CG023/CG031/3D X4
Aileron left = Cheerson CX-10 green pcb
Aileron right = Cheerson CX-10 blue pcb & some newer red pcb, CX-10A, CX-10C, CX11, CX12, Floureon FX10, JJRC DHD D1
Last used protocol is automatically selected if stick is in neutral position. Extra features (if available on aircraft):
Channel 5: led light, 3 pos. rate on CX-10 and FQ777-124, H7, inverted flight on H101
Channel 6: flip control
Channel 7: still camera
Channel 8: video camera, pitch trim (FQ777-124)
Channel 9: headless
Channel 10: calibrate Y (V2x2), pitch trim (H7), RTH (H8 mini/H20, FQ777-124), 360deg flip mode
(H8 mini 3D/H22)
Channel 11: calibrate X (V2x2), roll trim (H7,FQ777-124)
Channel 12: Reset / Rebind
- 411
